![]() | Home > Technical > Locking rear axle - E Diff |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
Just found the sign in from Eduardo's post for Topix, and apart from the Volvo gearbox query that I found the answer to with a search, mines listed as 'Locking Rear Axle - E Diff' - what does this mean, there are no external connections etc, don't suppose it has a limited slip type diff?
Also how do you find the supplying dealer from the code M4670???? Cheers Keith |
I thought the E-diff was a Disco 3 thing
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
I've just signed in to Topix and my vehicle info also states "LOCKING REAR AXLE - E DIFF ".
After jacking the rear axle up and spinning the rear wheels, looks like a normal diff, feels like a normal diff, acts like a normal diff therefore I think its a typo!
Keith Any thoughts on the supplier code?? Thanks Keith |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
TOPIx is a mess since it was put together, obviously IT people trying to put together something which needed JLR knowledge. Even the vehicle pictures were messed up on the legacy models 12 months ago. You still can't find things you want so when looking for a fuel injector bulletin, it could be under TSB/SSM or recall info, but then it won't be under 'Fuel' but under 'Engine'. Very frustrating...
