Home > Puma (Tdci) > big clunk from the rear
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
hi all
anyone out there get a big clunk from the rear somewhere when changing down gears? think it could be the diff, but not sure. Cheers
keith
puer claudius
Post #12731 7th Jul 2009 11:36am
bob neville
Had this on my supposed 09 defender, subsequently found out to be a sept 08 build, that LR replaced a week ago. The new April 09 build one does not have the problem at all along with not having rear diff whine on lift off from 60 mph !
On my LR experience the instructor did mention something about the cause, and I could be totally wrong here, but he mentioned something to do with the assist on the clutch and the the speed of release of the clutch plates.
On my old vehicle it was worse when I released the clutch quickly. I must admit, on my old defender it did sound like the rear diff as well.
Bob
Post #12734 7th Jul 2009 12:10pm
Grockle
Keith,is it when your auto box is down shifting itself or are you Censored it manually ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #12736 7th Jul 2009 12:26pm
bob neville
I forgot Keith's vehicle was an auto, so strike out the clutch theory !
Bob
Post #12737 7th Jul 2009 12:36pm
Bosun
I also get this relentless clunk when I change gear (unless I let the clutch up realy slowly, almost to the point of slipping it). Had new clutch, gearbox and transfer box, but still the same. Might this also be the diff, or diffs? Land Rover see to think it's normal, but I,m not convinced, because my TD5 was OK.
Bosun.
Post #12751 8th Jul 2009 8:37am
JohanH
Norway 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Had the same on my -08. In the end the dealer found that the bolt to the back axle were loose. I have not had problems with this since.
Cheers,
Johan H Defender 110 -08
Audi UrQuattro -88
BMW 2000 touring -73
Mercedes-Benz 250 -75
Alfa-Romeo 156 -98
Post #12752 8th Jul 2009 10:11am
bustduster
Similar problem with my June 08 110. The well recorded knocking/clanking when coming to a halt after a longish motorway run has been my only major problem. Had the brake drum and shoes replaced along with the updated clutch and flywheel but it still did not cure it. Off to the dealer again soon to try and fix again. I suspect it may be differential related as there is a loudish whine when lifting off from 120km/h and there is some backlash/clunk when changing gear (when lifting off clutch and pressing accelerator).
Post #12753 8th Jul 2009 10:27am
kljw
Grockle
it's when the box down shifts in auto. i have changed the change pressures a wee bit, and that has made a difference, but is still there. does not happen all the time, just at random moments.
when using it in manual, there is nothing, but then again, the change pressures are different in manual to auto. Cheers
keith
puer claudius
Post #12755 8th Jul 2009 11:06am
Grockle
It could be the slack being taken up in the drive train,or has it just started Keith ? 2.4 90 XS
Post #12756 8th Jul 2009 11:18am
kljw
Grockle
it has been there since day one, and has got allot better since i played around witht the change pressure. i guessed it may just be slack, so not that worried. as i have already done &.5k miles, i will wait and get the dealer to look at it when i get it serviced. Cheers
keith
puer claudius
Post #12761 8th Jul 2009 12:13pm
AndrewS
Or loose prop bolts
Post #12976 14th Jul 2009 4:24pm
