Home > Maintenance & Modifications > Rear Power Connector gone AWOL
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Today I planned to fit a 12V power socket in the rear of the 110 using the existing T-shaped connector that lives behind the speaker. Except it wasn't there. I had a good poke around and found a multi wire connector plugged in to the back door (no unused wires), the rear speaker connections and the rear lights. Nothing else.
I had a check on the left hand side, but nothing there either. Am I looking in the wrong place? Or has this been removed from the 2.2? Does anyone have access to the wiring diagram for the 2.2 to confirm that it should still be there?
Post #126742 25th Feb 2012 8:15pm
Laurie
Mine (TD5) was hanging down behind the rear chassis member (offside)
Post #126743 25th Feb 2012 8:19pm
Interesting as you should have a purple and a black wire
Post #126833 26th Feb 2012 10:25am
Lorryman100
Post #126891 26th Feb 2012 4:22pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Maybe this has been deleted on the MY12 2.2. I don't remember a second accessory socket back there being a factory option so maybe this is some sort of cost reduction.
Pete
Post #127028 27th Feb 2012 11:50am
Pete
Checked my MY13 out yesterday - hoping this might be there but no it isn't:
also checked other side just in case:
On the subject of quality - really Mr Tata - you can't drill a hole in the right place Crying or Very sad
Post #232199 2nd May 2013 8:25am
