![]() | Home > Puma (Tdci) > Speakers in a DCPU |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
How many speakers are there in a 110 DCPU XS? Is there just the two in the dash or do they have some in the back of the cab as well?
Thanks. |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Just the 2No 4" under the dash and 2No little tweeters in the top of the dash
Thanks guys.
Do you know if the wires will still be in the rear light panels like they are in a hard top? Was thinking could extend them back into the cab for some rear speakers. |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Yes, the wires are already there, with the correct fittings too.. so presumably if you find where the wiring loom runs then you could cut the wire back and feed it up into the cab.. but running the wires to under the rear seats isnt hard.
TRUST me, put a sub under the rear seats, put some expensive speakers in the dash and a better head unit. Sorted!! 110 Tdci Double Cab |
