Home > Wheels & Tyres > New zu/Mach 5 style wheels from 4x4 tyres.co.uk
TACK
Just seen these wheels, is the offset ok for 265/285 tyres?
Seams like a good price Thumbs Up Anyone brought these from 4x4 site yet?
http://www.4x4tyres.co.uk/challenger-wheels-p-1571.html
Post #123990 14th Feb 2012 9:53pm
RRUK
Spotted those a week or so ago and wondered the same thing.
I don't understand the offset thing, but I guess if you know what the offset is of your current wheels or the Land Rover standard , you can gauge what it will look like. Most LR alloys have an offset of 20 I think.
Someone much cleverer than I shall be along shortly to waft away the fog I just created. Cool 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #123999 14th Feb 2012 10:08pm
leeds
Just had a quick look and will make the following observations.
Load Rating? TBC presumably means To be Confirmed??
For comparison purposes Zu rims are rated at 1.4 tonnes/rim and are made in the UK
[quote]
The only wheel available to the Land Rover market which has been rated at a massive 1.4 tons per rim and passed the stringent TUV test approval at this weight. Designed to give your Land Rover the maximum wheel track while still complying with British Mot standards, these rims eliminate the need of expensive wheel spacers which can put excess strain on ball joints. Where as in the past other rims were sold for "off road use only" these meet or exceed UK, European, US, Canadian, Australian, South African, Swiss and Japanese on road regulations and meet wheel manufacturing specifications so wont affect insurance policies.
/quote]
So where are those rims made? What load rating are they? What standards do they meet?
Brendan
Post #124012 14th Feb 2012 10:34pm
IKke
Netherlands 1986 Defender 90 200 Tdi SW Keswick Green
How does it matter where they are made? Geographic location is a warranty for absolutely nothing Confused Scaling the real deal.
Post #124019 14th Feb 2012 10:50pm
leeds
Geographical location has been know to have severe quality control implications!
My main point however was lack of load rating and approval implications.
I for one would be unwilling to put rims on my vehicle without that sort of information as I consider good quality wheels and tyres as important safety features.
Brendan
Post #124052 15th Feb 2012 7:53am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Re: offsets, the offset is the lateral distance between the flange of the hub and the centreline of the rim. A positive offset means the wheel ends up set inboard, like most LR alloys (Boosts are +33mm). A zero offset rim on a Defender would make the wheel stick out the arches quite a bit, assuming it was a sensible width.
Post #124063 15th Feb 2012 9:31am
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Is the max load stamped on the wheel. I phoned them today and they said each wheel has max load of 1950kg
Sounds high....... 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #127674 29th Feb 2012 11:46am
Zagato
Leeds has a point. It has been mentioned by those in the trade on this forum that some of the alloy wheels sold are of dubious quality Shocked
I'd like some BFG KM2's on Dual Finish replica wheels but I'm not sure the quality would be great, needs checking, best to get oe stuff really Wink
Post #127677 29th Feb 2012 11:50am
get proper Mach 5s in 8J they are steel
Post #127688 29th Feb 2012 12:24pm
Glynparry25
Sounds high.......
Sounds rediculously high! Blinds and Tx wheels have a much stronger configuration and are only rated at 1.4or 1.6 (can't quite remember).
As Brendan says- wheels and tyres are what connect your truck to the road so you don't want to fit cheapos and then find they fail.
Glyn
Post #127691 29th Feb 2012 12:39pm
leeds wrote:
Quote:
... these rims eliminate the need of expensive wheel spacers which can put excess strain on ball joints. ...
I am not sure where this is a quote from (Zu website perhaps?) but someone's been smoking the crack pipe!
How can the use of wheel spacers possibly affect the "strain" (and clearly this word is also being used in a non-engineering sense) on ball joints?
There will be absolutely no difference in loading on any of the vehicle's supension and steering components whether you use a wheel with a spacer, or a wheel of the same width with the equivalent offset.
Totally agree with the comment about these rims though; unless the manufacturer can demonstrate that they are of good quality I wouldn't consider buying them, and I am certainly sceptical about the figure of 1950kg.
Post #127700 29th Feb 2012 2:16pm
Probally lbs Whistle
Post #127709 29th Feb 2012 3:42pm
they seem way too cheap to be any good .. when you think of the raw material cost, manufacturing, painting and finishing ...
ken wrote:
get proper ZUs
I agree Thumbs Up
Post #127744 29th Feb 2012 6:01pm
T1G UP
So true! Rolling Eyes
They look like Matt Lees old design
Post #127780 29th Feb 2012 6:47pm
McS
Erm, of course spacers will increase the "strain". If you use a 30mm spacer, then the mounting surface of the wheel is 30mm further out from the balljoint and king pins thus the "stress" increases. The only instance that would see you statement being correct is if the mounting surface of the wheels protruded further inward than the inside wall of the tyre.
I'll just return to my crackpipe now...
Ross The Scotia Winch Challenge
Post #127904 1st Mar 2012 8:38am
