Home > Puma (Tdci) > Indicators dont flash |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Sounds like either the switch or the flasher relay (more likely the switch) Used to have a big problem with this in Belize where the contacts were corroding in the humidity.
Glyn |
25th Jun 2009 8:26pm |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
Yep. Flasher relay. Had mine replaced a few months ago for the same problem. 2007 Defender 110
1970 Alfa Romeo 1750GTV |
26th Jun 2009 1:00am |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 809 |
I have this too, but intermittent (like maybe once or twice a month).
Dealer can't find a fault (and of course they're behaving when they go in the garage), but tow electrics are badly corroded so they are being replaced in a couple of weeks time. Maybe I should get them to replace the relay too just in case? |
26th Jun 2009 8:27am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Don't forget that if a bulb has failed the system won't flash on that side of the vehicle either. It doesn't have to have failed either it can be a corroded/faulty terminal or bulb housing causing the problem, or trailer plug (as mentioned). But if it's happening on both sides then I'd suspect the relay first. 110 2.4TDCi
110 300Tdi LROCV ::: AULRO.com |
26th Jun 2009 8:36am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
We had problems with corroded terminals on our TD5 as Derek said,have given the Puma's bulbs and connectors a good coating of vaseline. 2.4 90 XS
26th Jun 2009 9:44am |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 |
Started off as infrequent- now more often than not. Odd thing is that the alarm sequence of flashes via the fob starts them up again Relay should be a quick fix then. Might get seat belt replaced at the same time (wife keeps slamming the door on it )
26th Jun 2009 6:41pm |
9/10's, clip the belt behind the back rest ajuster that keeps it away from the door stricker 2.4 90 XS
27th Jun 2009 7:24am |
Its a bit late for that shes completely mashed it up by repeated slamming Pimped black '07 Puma
Equally Pimped Black Pick up Truck Rollin deep |
27th Jun 2009 7:32pm |
Yep flasher relay> Big to Charles Hurst Battersea for quick turn around, they didnt have the part so they scavenged it off a new vehicle, was very impressed by their can do attitude. Pimped black '07 Puma
10th Jul 2009 12:16pm |
