![]() | Home > Maintenance & Modifications > Useful modifications while the dash is in bits |
PeteA Member Since: 14 Jan 2012 Location: Lancs Posts: 44 ![]() ![]() |
I had the pleasure today of replacing the windscreen wiper drives on my XS 90, 3 hours later and with the dash in a 1000 pieces i thought i 'd ask what are the best mods to do before I put it back together again. Ideas were;
Bigger Mud stuff demisters with side vents - are they any good, at £130 i think there a bit pricy http://www.mudstuff.co.uk/DefenderVENT.shtml Auxilary harness / switch for roof lights (no lights fitted yet) Rev counter instead of the clock Any other ideas or comments welcome soon as when its back in one piece I intend it to stay that way! Pete |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Install a wiring loom & switch for a heated windscreen?
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
LRM [or was it LRO] did a mini review of those demisters last month ... didnt rate them too highly
![]() And for what are basically a pair of shaped plastic tubes .... £130 ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
I think you are thinking of a different product. The ones mud stuff do are very good, the ones in the mag where ![]() Andy |
These are the crappy ones
http://www.defenderdemister.com/ Andy |
I stand corrected ... apologies to mud Stuff ![]() |
Thanks Andy I've seen these and I am not impressed, have you tried the Mudstuff ones? Its either fit those or try some homebrew ones. I think the double screen washers and wiring for heated screen are a good idea, thanks for the suggestions guys Pete |
Paullr90 Member Since: 06 Feb 2011 Location: Derby Posts: 93 ![]() ![]() ![]() |
[/quote]
Thanks Andy I've seen these and I am not impressed, have you tried the Mudstuff ones? Its either fit those or try some homebrew ones. Pete[/quote] No I have not tried them myself, but have seen them and like ![]() Andy |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
Has the wiper motor enough power to spray through 2 screen washers? Or is at limits like everything else.... Puma 110" SW
Hi Mark I take it you used the existing two holes in the bulk head that are currently plugged ? What did you seal up the old nozzle hole with? PS like your motor, same year as mine but mines alot less modified ![]() Cheers Pete |
Swap the front wiper relay for the VW variable one.
Run a link wire to the rear wiper switch to provide auto wash wipe when used with the intermittent rear wiper kit. Possibly LED instrument lights? One of the things I remember doing years ago to a Series III was fitting a restrictor in the passenger side windscreen demister pipe to divert more airflow to the drivers' side. Less useful if you have a heated screen, of course. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Darren Where is the wiper realy located, I suspect behind the instrument module that i have just replaced ![]() I've a heated screen so no need for the airlow mod Pete |
Yeah, the relay is behind the instruments. Take a look HERE for more details.
The link wire thing is part of the instructions if you buy the rear intermittent wiper kit that can be found on eBay. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
