Home > Puma (Tdci) > Gearbox / Clutch Chatter in Neutral
Page 2 of 2 <12
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
This was what was causing my Defender to be noisy in neutral.....
][/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #123246 11th Feb 2012 3:34pm
ZeDefender
Did it always make the noise in neutral or only when the vehicle was hot?
Matt Tell someone you love them today because life is short.
Post #123256 11th Feb 2012 4:02pm
CRJ
Always - sometimes a lot worse than others - believe it was worst when warm. Changed it when it started slipping in 6īth. Did 80.000 km on original clutch.
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #123260 11th Feb 2012 4:07pm
ZeDefender
Cheers Smile
Post #123263 11th Feb 2012 4:23pm
CRJ
Actually it was pretty noisy when I bought it - at 45.000 km - but it did 35.000 km with noise. It went absolutely silent when it was changed.
Regards
Puma 130 - 08- sold
110 CC 2003
Post #123266 11th Feb 2012 4:29pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
The original cluch of my Td4 is noisy when the engine is very cold and the outside temperature is near zero °C or below.
When I turn on the engine in neutral I can heard a fairly loud noise that disapper when the clutch pedal is depressed.
After some minutes of engine running, when the engine temperature slightly increase the noise fade away.
The colder the outside temperature, the louder the noise.
Except this noise I cannot feel any other problem, the clutch is working fine.
Is these the syntom of a soon-to-fail clutch ?
Post #123298 11th Feb 2012 7:44pm
CRJ
Mine was noisy all the time - and the last 5.000 km it was also pretty bad when engaging - making a metallic "Clang". Could be that it is just your release bearing that is "talking" a little bit. I woudnīt worry before it sounds like a bag of nails all the time - except if it is still under warranty. My old 130 300 TDI rattled for 200.000 km.
Puma 130 - 08- sold
110 CC 2003
Post #123315 11th Feb 2012 9:12pm
110SEB
Going in to Foley's on Thursday for a new clutch. I'm not going to put up with a disintegrating clutch 500 miles into France with the associated damage.
Post #123607 13th Feb 2012 11:39am
Page 2 of 2 <12
