![]() | Home > Technical > Interior Light Fuse |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
I�ve managed to blow the fuse while I had the rear interior light out, yes I know I should have been more careful, but now I can�t find the right fuse. Oddly the radio has stopped as well. Any ideas?
Merlin |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2468 ![]() ![]() ![]() |
dashboard or under one seat Puma 110" SW
james975 Member Since: 07 Nov 2009 Location: Edinburgh Posts: 53 ![]() ![]() ![]() |
Under the drivers seat .
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Fuse 30 in the dash fuse box - 10A rating
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
once again this forum proves invaluable, just blew my fuse fitting LED interior lights, couldnt find which fuse and the manual was no help, but the answer was here DEFENDER 90 TDCI XS,
Easily done
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
I've done the same - blown the fuse.
Is this the right replacement? The red 10A one? http://www.ebay.co.uk/itm/20pc-Replacement...4897.l4275 |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
i also blew the rear light fuse, but my radio still works? haven't figured out how to fix yet..
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Simple way... Pull your fuses one by one and check if they're blown
From memory it's in the bank on the bottom left of the dashboard fuse box. Defender 90 XS TD5 (03 Reg) |
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 ![]() ![]() ![]() |
Did the same! under drivers seat TD5 pull all the fuses till you find the right one! Simplez DRW I built a garage for my Mini
With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and ![]() |
I guess I just need a new 10A fuse?
They're all the same size right? |
Yes, they're all the same size. Darren
Excellent thanks!
OK - I checked all the 10A fuses and they seemed fine. I don't want to start pulling all the fuses in case I upset the immobiliser or alarm.
Can anyone let me know which of these is the interior lights fuse? (The radio doesn't work either!) ![]() Click image to enlarge The fuse layout diagram isn't much help. ![]() Click image to enlarge |
