![]() | Home > Technical > Wiring up interior lights questions. |
jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134 ![]() ![]() ![]() |
I'd like to know this as well as I'm in the process of purchasing some rear panels for my hard top too. Tdci 110 DC
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
'Scotchlocs' - Don't use them they are the connectors of Satan, a proper bodge job. Use proper crimps with a proper ratchet crimp tool. Pete |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
OK, making progress, what type of crimps and how?
![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
First off I'd suggest you use Vehicle Wiring Products for your supplies and also Thinwall cable. What are you intending to wire up? And how would you like these things to work?
Crimps: http://www.vehicle-wiring-products.eu/VWP-...sterms.php I'd suggest female and male fully insulated spade terminals (as your main connectors) you may also require some ring terminals too.
Crimping tool: http://www.vehicle-wiring-products.eu/VWP-...crimps.php |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
My preferance is to cut the cable, bare back and put heat shrink over the cable, then solder all three together.
If done corectly a far more secure joint than crimps or evil scotch blocks. Looks very neat if you use heat shrink too, keeps it all together as well. |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
The wiring for the rear interior lights comes up the drivers side A-post. Once under the headlining there will be a connector that has the wiring for the front light and blanks in this plug for the rest of the wiring that isnt fitted on your truck. You can either wire into whats there or you can buy a new part of that harness with all the wires there ready to connect. Also the wire for the rear door switch is also in that connector and runs under the headlining and down the side of the door. The rear door switch is only a few £'s so worth fitting while your headlining is out. You can also fit the motion sensor for the alarm while you in there if you want but it needs turning on with a computer before it will work. I cant remember the wiring colours but think the rear door switch is a purple wire and you can work the others out with a meter.
Pete. |
I take it then I can take the feed from the front light for my two rear LED's, and put a manual switch in between, so that I can prevent them coming on with the automatic front light.
I plan to put the switch in the MUD side panel to my right shoulder, so I can select if the rears come on with the front or independently. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Yeh no problems there, the feed for the rear light in the headlining (if it was fitted) would run off the same wires as the front as standard.
Pete |
By the way each light has 3 wires to it, one earth, one permanent live no matter what and one that is powered when a door is opened or unlocked with a remote.
