Home > Puma (Tdci) > Towing Electrics Help.
biffabacon67
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I have just bought a dixon bate adjustable tow bar and N Type towing electrics. fitting the tow bar was no ploblem, but where is the block connector for the electrics? I have a 2010 MY defender 110 XS station wagon.
Any help would be appreciated.
Steve
Post #122170 7th Feb 2012 7:28pm
TJ101
Right hand rear wheel arch, behind the thin black splash panel, fitted against the rear panel,, pull back enough to feel around for the plug California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #122183 7th Feb 2012 8:00pm
biffabacon67
Spot On, Many thanks. Will get it sorted tomorrow.
Steve
Post #122184 7th Feb 2012 8:04pm
TJ101
Steve
Thumbs Up easy job with the gen kit,, are you fitting the socket into the cross member hole ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #122188 7th Feb 2012 8:10pm
biffabacon67
I wasn't going to, i was going to use the bracket on the tow bar. It's a genuine landrover socket, so is using the cross member hole better?
Post #122191 7th Feb 2012 8:13pm
TJ101
Have put the socket in the hole for the last 4/5 Defenders,, previously would have to change it after a few years due to crud or damage, been fine since,,
Plus also when used offroad the whole towbar is removed to avoid it acting as a plough,, 5 min job, as the electrics don't need to be touched California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #122198 7th Feb 2012 8:20pm
biffabacon67
Sounds Fair enough. Is this the square hole in the middle of the big round hole in the middle right of the rear cross member as used by the military to mount their electrics? If so do i need a plate or any thing to mount it?
Post #122200 7th Feb 2012 8:23pm
TJ101
No,, i use some stainless self tappers in place of the machine screws, the loom goes through the hole, then down to the plug behind the panel,, 15 min job California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #122203 7th Feb 2012 8:26pm
biffabacon67
Brilliant,
Job sorted for tomorrow.
Many thanks again
Steve
Post #122204 7th Feb 2012 8:28pm
TJ101
Not the best pic
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #122208 7th Feb 2012 8:36pm
biffabacon67
Looks Good!!
Love the number plate!!!!
Post #122209 7th Feb 2012 8:37pm
TJ101
Thats the "show" plate Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #122212 7th Feb 2012 8:41pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I got stopped and lectured by Plod about my "show plates" a couple of weeks back... £60 fine, £35 for new plates and a b0ll0cking from the DVLA warning I'd lose my number if I EVER mis represent the registration.. I even had to send photographic proof I'd changed the plates for legal ones!! Big Cry Big Cry ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #122469 8th Feb 2012 8:25pm
BigMike
Crossmember definitely the neatest and safest place for it Thumbs Up
Post #122487 8th Feb 2012 8:50pm
£35 for new plates is a bit steep don't you think? On plates i can understand the law but they even will have you for the small detail on the bottom of the plate too (details of manufacturer and BS mark)
Post #122569 8th Feb 2012 11:40pm
