Home > Group Buys > 2nd run group buy for the integrated remote key
How many key do you want?
One key w/o programming POD
11%
 11%  [2]
Two key w/o programming POD
5%
 5%  [1]
One key with ONE programming POD
50%
 50%  [9]
Two key with TWO programming POD
22%
 22%  [4]
More Options .....
11%
 11%  [2]
Total Votes: 18
Page 1 of 3 123>
dgardel
Italy
If you have the Nanocom or similar, you do not need the Programming POD
If you haven't the Nanocom or similar, you NEED ONE Programming POD for each key bought.
The programming POD need to write the Key code inside the Alarm ECU.
The Keys are 433MHz (Europe). If you want use outside Europe need different frequency, pleas tell me by the forum
Late I'll post the price....
£1,00 more for each key for forum donations
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #122020 7th Feb 2012 9:07am
Zagato
Roughly what price would they be Dan?
Post #122034 7th Feb 2012 9:54am
dgardel
Italy
Depending from the number, but I think:
- 65-70€ w/o POD
- 85-90€ with the POD
delivery to your door in Europe included, more or less. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #122036 7th Feb 2012 10:01am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Count me in for one with programming pod.
(does the price include the LR carabinerr keyring Mr. Green ) joking of course.
Can a numpty do the programming?
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #122040 7th Feb 2012 10:27am
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Can I change my vote to one with prog thing?! 90 Puma HT
Post #122044 7th Feb 2012 11:02am
log11
Greece
Count me for one without POD
Post #122051 7th Feb 2012 11:33am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
What exactly is the POD ? Embarassed an extra bit that comes with the key ? How does it work ? Neutral Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #122057 7th Feb 2012 11:44am
Jammer600
Is This the same key but without the pod thing?
eBay Item No. 150753638073 90 Puma HT
Post #122067 7th Feb 2012 12:08pm
dgardel
Italy
I think yes.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #122102 7th Feb 2012 4:42pm
dgardel
Italy
you put the POD on your Defender OBD port, and it write inside the alarm ecu the 4 digit key code for match it.
After the programming the POD delete itself the information stored (Ethan Hunt this message will be destroy in 15 second......) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #122103 7th Feb 2012 4:45pm
d j hutton
Just checking,
will this writing of new code still allow the use of the original key/fob as well?
If not I'm probably going to need two!
Buy British 🇬🇧
Post #122110 7th Feb 2012 5:07pm
Fifth Horseman
IIRC you can have up to four fobs registered with the AS10 alarm system
(Voted for one - no pod)
Post #122152 7th Feb 2012 6:46pm
bob neville
Voted for two plus two pods Thumbs Up
2013 Defender 90 CSW - sold
Post #122160 7th Feb 2012 7:03pm
Lorryman100
Thumbs Up
Post #122245 7th Feb 2012 10:23pm
FG
Sweden 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
This I like. One key+one Pod for me!
/FG
Post #122273 8th Feb 2012 6:57am
Page 1 of 3 123>
