Home > Td5 > Td5 defender just cut out while driving
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Well, not had it long. Just getting into the whole Landrover thing and enjoying it and it looks like my defender thinks I need initiating into the whole Land Rover scene.
Well I drove to Sainsburys 2 miles, shopped for 20 mins, then drove home and after 2 mins return journey the engine cut out.
Tried to re-start and there is no fuel pump noise.
Pulled out the relay (yellow one under drivers seat) and refitted, no change.
Got towed home and checked the relay, a 9v battery activates the relay so is it ok?
Could it be the immobiliser?
Thanks in advance for any replys, thought I would ask if anyone has had the same problem.
Know what I am doing tommorow.
Steve
Post #12161 19th Jun 2009 11:51pm
Grockle
It could be the immobiliser as you say,have you tried locking and unlocking then see if it fires. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #12166 20th Jun 2009 8:24am
Steve B
Hi Grockle,
Thanks for your reply.
Just fixed it. Smile Smile
The inertia switch had broken off the bulkhead and fell down.
So pleased it was something simple, started to get thoughts of fuel pump/ecu £££££££££££
Thanks again for your help.
Steve
Post #12171 20th Jun 2009 9:25am
