Home > Technical > TDCi headlights
67_6Cyl
France
TDCi headlights
Hi all,
2007 TDCi, 110 SW (not that it matters)
Driving home tonight with headlights on I lost all lights (dash / side and headlights). Switching everything off, and back on again i have working dash and side lights, but then when I try the headlights I lose everything again. There is no difference if I try dipped or main beam, neither work, and both cause the loss of loss of dash and side lights.
All the fuses are ok. Now, I don't have any idea what would cause this.
Where do you guys reccommend that I start looking before I take it to the stealers?
Thanks guys, any help would be appreciated.
Jon
Post #120943 3rd Feb 2012 6:31pm
Happyoldgit
Check the main light switch on the column, Defender wiring being what it is the switch contacts have been known to burn out. Steve.
http://forums.lr4x4.com
Post #120962 3rd Feb 2012 7:02pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
we had this also lately and i looked a bit closer to the switch,
what happens is that the plastic plate (which on older models was a printboard type material) where the lower contacts are pressed in (some of rivet style system) melts and the contact point simply sinks down under the switch spring pressure till it sits so low the upper contact plate cannot reach it anymore.
You dont have to buy a new switch (not that they are expensive but it will fail again). Put a dot of solder on the contact so it makes contact again and wire in a relay and your issues are solved.
Try driving a long trip with the lights on, you'll see it wont matter how old or new your switch is. Our new one failed after about 5 hours of driving.
just my 2cents
Smile
Post #120966 3rd Feb 2012 7:14pm
67_6Cyl
France
Thanks guys.
It's -10 outside, so it can wait untill tomorrow I think!
It doesn't sound like a major job.
Jon
Post #120981 3rd Feb 2012 7:35pm
67_6Cyl wrote:
Thanks guys.
Jon
cooler than that in the UK Rolling with laughter
Post #120987 3rd Feb 2012 7:41pm
67_6Cyl
France
bpman wrote:
67_6Cyl wrote:
Thanks guys.
Jon
Forcast -15 tonight! I assume that the back of the switch has standard connectors, so it will be a quick job to take it out...... So that I can mend it in the warmth of the kitchen...........
Jon
Post #121022 3rd Feb 2012 8:36pm
67_6Cyl
France
Thanks guys.
Switch out, blob of solder on, and back in, in less than 45 minutes including procrastination and making a steering wheel puller.
It was only the rivet/pin for the main beam that had melted and sunk into the PVC. Judicious application of heat from the back, pin pushed back into place, and a blob of solder to hold it onto the brass plate that connects the three outermost pins.
Now I have working lights again.
Once again, tanks for the quick and accurate diagnosis.
Jon
Post #121419 5th Feb 2012 9:59am
out of interest, have you upgraded your bulbs ?
Post #121544 5th Feb 2012 6:48pm
Zagato
Had this happen on my TD5 Rolling Eyes Did the same fixed with solder. I keep meaning to buy a spare as an easy fix on the road, crazy price for the new part though Mad Think it is £40 or £70 Big Cry
Post #121642 5th Feb 2012 10:08pm
tatra805
BPman: I do, the osram night breakers but they are theoretically the same wattage as original.
For the solder solution, dont forget to wire in a relay or you're going to have the same problem in short time.
I looked at the cabling and sizing is not the problem (a bit on the weak side i agree, but for normal bulbs sufficient)
To my opinion the contacts of the switch are the biggest trouble, i have my relay wired and hidden next to the switch itself, no need for new wiring and takes the strain from the switch. No more re-soldering in the future.
Smile
Post #121659 5th Feb 2012 10:43pm
67_6Cyl
France
No, the masochist in me likes the 55W glow-worms.
Jon
Ps when I have the time, I might put them on a relay.
Post #121666 5th Feb 2012 10:59pm
I have piaa extreme brilliance / white blah blah .. 55/60Ws that are really white but cost €70 but still cheaper than LED headlights !
in fact, I saw an Austrian Defender in the UK on Saturday night running LED headlights and they had filled up with snow .. whilst my H4 PIAA filament bulbs were warm enough to melt the snow ...
Post #121674 5th Feb 2012 11:27pm
whilst my H4 PIAA filament bulbs were warm enough to melt the snow ...[/quote]
Not a fan of LED lighting full stop to be honest seems a lot of hype! tried a LED reversing light bulb at it seems duller and less bright than standard. not for me
Post #121683 5th Feb 2012 11:44pm
given that some folk wil spend £70 on the bulbs, it doesn't seem quite so bad for the switch. Genuine Lucas switches are generally available for much less that the same part in a Landrover box.
Trouble is there's no telling if it's the dip switch or the on/off switch that's going to melt first, and the dip switch is a steering-wheel-off job to replace, not ideal at the side of the road.
A dodge that has got be out of trouble with a melted dip switch before now is to short out the dim-dip resistor, so dip beam was on in the sidelights-on position. Obviously this only works on models with the useless dim-dip feature though.
The best solution is to do what Landrover should have done in the first place, and add a relay into both dip and main headlight circuits. I have trouble comprehending why they still run the full headlight current through the two switches; I imagine that Landrover is by now possibly the only car maker in the world to do this!
Post #121734 6th Feb 2012 12:01pm
agreed, my €70 PIAAs are 55/60W's so the same draw as your regular hellas or phillips.
would make much more sense to put a relay in for dip as well as full Thumbs Up
Post #121757 6th Feb 2012 12:34pm
