Home > Maintenance & Modifications > Removable Front tow Hitch!
Zagato
Post #120066 31st Jan 2012 1:00pm
Laurie
Sensible price too Very Happy
Post #120073 31st Jan 2012 1:28pm
noworries4x4
Mine is home made, fits both sides and locks into the jacking holes seconds to fit. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #120142 31st Jan 2012 5:59pm
110ross
United Kingdom 2001 Defender 110 Td5 CSW Chawton White
Same as the Simmonites one but cheaper.
(same picture too!)
Post #120242 31st Jan 2012 9:52pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Any pix, I have a spare 5 hole adjustable plate I was thinking of modifying for this purpose
cheers stoker Cool 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #120258 1st Feb 2012 6:34am
I think i've also seen ones that fit into the steering guard .. or was that removable front winches ?
Post #120262 1st Feb 2012 7:36am
Zagato
Steering guard. Lorryman has one Thumbs Up
Post #120264 1st Feb 2012 7:45am
JSG
Nice idea for moving big trailers about - I assume it slips over each side of the dumb iron but I'm not sure a standard bumper (not the galv one shown) would be strong enough. John
2011 Tdci 110 CSW XS
Post #120373 1st Feb 2012 5:35pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
I had a removable front tow bar (custom made) on my previoius Disco. At first I diligently used to take it off and stow it after each use. After a couple of months it stayed on permanently for the next four years. With the Defender I again looked at all the options including having a custom heavy duty front bumper made but in the end I bought a couple of 5 inch drop plates, cut one in half to use as a backing plate and bolted it onto the standard bumper as a permanent fixing. I welded a bracing bar to the side which bolts to the chassis using an existing hole where you put the jate ring.
Apologies for the cr**py pic - will aim to take a better one tomorrow.
Post #120387 1st Feb 2012 6:04pm
chiefstoker
Cool But I just dont like the idea of having a permanent fixture really for insurance reasons 2005 TD5 90 Hard Top
Post #120419 1st Feb 2012 6:56pm
Eduardo
Good idea Thumbs Up Eduardo
Post #120484 1st Feb 2012 9:03pm
Lorryman100
I have the Safari Equip steering guard with the 2" receiver that allows the fitting of a drop plate with towball, recovery billet or a winch mount.
It only gets fitted when needed, though I still haven't found a need for it being fitted yet.
Brian.
Post #120634 2nd Feb 2012 3:55pm
cobs
better pic of my (non-removable) one
Lorryman - like the idea of yours - when you do have a need they are worth their weight in gold. It's much easier to control a long trailer/caravan with it on the front rather than the back. One consideration is whether to go for centre mounted or to one side - I've always found it useful being able to see down one side.
Post #120652 2nd Feb 2012 5:20pm
Brian.
Proper job Thumbs Up
Post #120657 2nd Feb 2012 6:05pm
BigRuss
Brian.
I think it looks good but can't help thinking it a bit of vlad the impailler when off road! Russell
2011MY 110 XS USW Black
Post #120660 2nd Feb 2012 6:11pm
