![]() | Home > Maintenance & Modifications > fitting tablet pc in a defender, for mapping etc |
pathfinder Member Since: 31 Mar 2011 Location: lancaster Posts: 40 ![]() ![]() |
I have been using Memory map for years on a PDA and have found it invaluble, however technology moves on fast so I have installed memory map on an Ipad that I recently bought, I mounted it with a cheap windscreen suction cup mount but found that it had a tendency to fall off! so I worked out what I would need to build a more secure mount, and here is what I have come up with
![]() firstly is the ball fixing. ![]() Click image to enlarge here is the cradle fixed and positioned out of the way. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Angled around for driver view. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge :D Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
neat job, the ram mount kit is expensive but great quality, I have mounts in both my land rovers
![]() if you look hard enough on the ram mount website, you can find a pdf catalogue with all the mounts, fixings etc |
Very nice set up
![]() I am trying to work out a similar solution on my Puma, I find the flexible arm moves too much and my navigator has to hang on to the tablet pc ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
hey Bob,
here's my set up in the puma (i also use the same arm and cradle in the tdi) I've not tested it in the puma off road (yet!) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Thanks Steve - that will work
![]() Do you have the part number of the ball fixing you used on the grab handle ? Thanks Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
hi Bob i think it's "Base with Ball and Straps (RAM-108B)" = �14.43 Steve |
May have answered my own question - RAM-B-108B ??
you did but I just beat you
![]() (it comes with 2 clips a large and medium and a rubber sleeve) |
Ram mounts are extremely useful kit. Ipads etc can be mounted on the Defender grab handle. Also can be mounted on flexi arms.
![]() Click image to enlarge ![]() Click image to enlarge Flexi arm is mounted under seat rail bolt. ![]() Click image to enlarge Can not find the photo of the 2.5" ball mounted on the bulkhead. There are 4 different sizes of ball dependent on the weight of the item to be held. We do have a range of Ram Mounts in stock. Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
I bolted my ram ball to the grab handle,, now in its 4th Puma,, works fine,,
Run with a tough book, being a bit heavy and would move,, but only on rough washboard roads in Morocco and the like For a later trip, tried a touch screen, that worked better,, but the I pad works the best ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Main Brian James Trailer Dealer for South West UK |
Tim - you must show me how you do that "discreet" wiring :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
My Ram Ball is bolted to the MSS cubby (neat wires
Fitted only for a 3 weeks trip,, left no holes, cuts, marks or brusies ![]() Main Brian James Trailer Dealer for South West UK |
