![]() | Home > Puma (Tdci) > It's arrived!!!! |
Welcome,why are you taking it to pieces already ? 2.4 90 XS
bazzam111 Member Since: 29 May 2009 Location: inverurie Posts: 8 ![]() ![]() |
I bought an AVT Sentinel GPS tracking system and want to fit it.
Heard they were good and expensive NO running costs!!!! Not to mention the new Pioneer head unit with Bluetooth for the phone ![]() |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
Welcome Bazzam111. Hope you enjoy your Defender.
Following is the part of the workshop manual relating to the console removal. https://www.defender2.net/gallery/albums/u...lation.pdf The radio unit has a pair of holes at each side. I bent two lengths of stout wire into a "U" shape and inserted the ends into the holes to disengage the clips holding the unit into the console. With some jiggling it came out. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
Hi CY
![]() Unscrew all the screws you can see on the panel and pull ![]() |
Did you mange to fit your bits bazz ? 2.4 90 XS
OK Sit rep!
Radio was a bit of a ![]() Screws out, panel off with sharp tug ![]() Thanks one_iota for extract from the manual, very usefull ![]() Tracker not fitted yet, waiting for new Pioneer head unit to arrive so will do that in a oner. Fitted all the tracker aerials in out of the way places (that was fun ![]() Just got to find permanent live supply for the unit. And thanks you lot for all your tips ![]() Done a grand total of 132 miles so far!! cheers, Bazza |
CY Member Since: 21 May 2007 Location: Scotland Posts: 18 ![]() ![]() |
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Was just thinking that, bazzam111 is my dad!
![]() Rebuilt 1996 black/white Defender 90 300 TDi |
