![]() | Home > Off Topic > Land Rover 109 Crew Cab |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
Does anyone know for sure, if a Land Rover Series ( II or III) 109 Crew Cab ( DOuble cab) ever left the production line, in that form, originally ?
I've seen a few but wanted to know if this was an original spec that could be ordered ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
No. Certainly not as a production model anyway. There are quite a few home-builds around though, as it's largely a nut and bolt job. Darren
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
I would disagree,
I have seen a few, the last one I saw was al the LR orphanage. I seem to remember it was an LR Special Build. 2002 Defender 110 DC |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
The one the orphanage had was not a factory job, but a very good private conversion. The factory did not offer them, and there was not much demand for them anyway. The double-cab is a very modern thing. The first one Landrover ever made was definitely a 110, in fact I think it was a proper Defender too, so no earlier than the early 1990s. It was several years before they became a factory model though. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
There was a factory built one on an early 200 but almost certainly a one off (James Taylor has details)
Series wise the Rumsey brothers have a 2a that looks like it may have been a factory built double cab, very very high standard if not |
I think we are on about the same vehicle, blue one with a tilt frame? (The 110 I am on about) 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
That's it, a JxxxOAC plate from memory (I could be wrong on that though!)
J366OAC. Page 248 of james Taylors book "LAND ROVER 60 years of the 4x4 workhorse". 2011 110 USW
Need to get a copy of that!
Did it have side stripes or not? |
Thanks guys!!
![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
