Home > Puma (Tdci) > vibrating gear stick
yanto
Wales
Hi all
have seen a topic on here about vibrating gear stick under load, and have tried to search for it but im too dim to work out the search engine on here? Can any one help plz??
Thanks
Post #118209 24th Jan 2012 7:13pm
Killer90
Site Sponsor
hi its a common problem on pumas i have read some over threads with same problem and in work we had a customer with a vibrating gear stick, turns out its not the actually stick but the piece which the stick goes into if that helps Thumbs Up
Post #118221 24th Jan 2012 7:37pm
RED-DOT
Wrong... they were under the tolerance and LR dealers change them if within warranty. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #118231 24th Jan 2012 7:53pm
yanto
Wales
Thanks red dot but im out of warenty.do you know what part i need to get?
Thanks
Post #118233 24th Jan 2012 8:00pm
Killer90
Site Sponsor
yer and when they change them it happens again and now the gearstick part is on back order due to land rover inspecting the fault so no not wrong Rolling Eyes
Post #118239 24th Jan 2012 8:28pm
Grockle
I knew a girl who would have loved to have had one Embarassed Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #118298 25th Jan 2012 8:18am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Laughing
Post #118301 25th Jan 2012 8:44am
Fifth Horseman
Post #118428 25th Jan 2012 6:14pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
If you pull the gator down the bottom of the stick, you then can see two clip either side, un clip then shake, you should fine the weights on the stick rattle! A simple bit of card to wedge between the stick and weights sorted mine out Smile 90 Puma HT
Post #118753 26th Jan 2012 8:10pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
I don't get the bit about pulling down the gator...? I thought you would have to pull it up to get to the gear stick clips? Can someone explain what to do?
Thanks
DAZ110
Post #118765 26th Jan 2012 8:22pm
Jammer600
If you pull the gaitor up you e gotta sort all the carpet or whatever you have out! It's a right pain, loads easier to pull down Smile 90 Puma HT
Post #118769 26th Jan 2012 8:33pm
DAZ110
Ok thanks, will give it ago....anything to stop that vibrating!
Post #118772 26th Jan 2012 8:39pm
