Home > Technical > Thrash or not to thrash?
Page 3 of 3 <123
ken wrote:
Can't beat an ERF with a round the clock box or a Daf 2800 with a straight cut box never fooked a change going up shap or the Dublin by dawn run via Holyhead Thumbs Up Conway arch always fun Mr. Green
AND someone accused me of techno-babble ...
Post #117184 20th Jan 2012 10:20pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
um........what is exhaust braking Question BM52
Post #117189 20th Jan 2012 10:35pm
rossy
Question Shocked er... that would be an ecumenical matter.... Laughing
Post #117190 20th Jan 2012 10:37pm
T1G UP
Jake brake explained
&feature=related
And a exhaust brake
&feature=endscreen&NR=1
get one for the defender?!
Post #117192 20th Jan 2012 10:46pm
bm52
Thanks TIG, i had no idea they existed, what a great use of engine power/torque to slow you down.
cheers BM52
Post #117193 20th Jan 2012 11:07pm
T1G UP
thats the low deep rumble you here from lorrys when going down hill
Post #117196 20th Jan 2012 11:17pm
Exhaust brake and full gas leaves a full smoke trail behind
Post #117197 20th Jan 2012 11:19pm
RED-DOT
Exhaust brakes cause huge upper cylinder pressures and the heat generated absolutely cooks the exhaust valve stems which melt the rubber O ring seals which soon causes oil to run past and burn on acceleration and more so on decelleration. Modern engines cut the fuel off as soon as the EB is applied. Clever hauliers disconnect due to this and they know the drivers can use in situations where the footbrake should be utilised. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #117199 20th Jan 2012 11:46pm
Sorry not a clever idea
Exhaust brakes are invaluable on long descents they save the main brakes for when you need them . Seen many a rig pulled over with cooked brakes.
Post #117205 21st Jan 2012 6:03am
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
T1G UP wrote:
And a exhaust brake
Amazing haircut on the dude Mr. Green 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #117410 21st Jan 2012 9:38pm
bm52
Today i did about 100 miles mainly on B roads cross country through Kent/Sussex and i don't think i went above 3k at any time, cruised mainly around 1600 - 2000 without effort or any strain.
one short M23 part but that was less than 2.5k and maybe up to 3k as i went through the gears to get up to speed.
torque not revs seems to be the way Smile BM52
Post #117415 21st Jan 2012 9:47pm
Page 3 of 3 <123
