Home > Td5 > Wiper motor problems |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 |
Still not figured this out yet
Had another look today at the switch wiring, where I joined all the wires together colour to colour, as the 300tdi Plug was different to the TD5 plug. Realised that there were two white/green wires, so swapped them around and then ended up with nothing in slow and fast speed, and would not turn off in stop and intermittent, so no better off! Al....(confused) 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
22nd Jan 2012 7:42pm |
Finally figured it out. Checked all the earths and wiring volts and all was ok.
Realised today that the squirty didn't work either, so checked the wiring for that. Couldn't get a continuity for the earth so changed that, then couldn't get 12.5v on the black/green wire. Then noticed on the TD5 loom there are 2 black/green wires, so tried the other one and hey presto squirty worked, and also wipers as well! Why goes TD5 look have so many earth wires that do different things, not to mention wires of the same colour doing different things as well! Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
27th Jan 2012 6:59pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
If Solihull were to tell you that, they'd have to kill you. |
27th Jan 2012 7:07pm |
