![]() | Home > Maintenance & Modifications > Extended Breather and Air Gaps |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I decided now that my tank is nice and clean I wanted no more chance of water in the breather.
Dealer never bothered to change the breather so I decided to extend it into the cab. While doing this I noted a lot of openings below the speaker panels which I siliconed up - thanks Shorty for that tip. Some pictures atached with my idea - hope it works without any fumes. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
people more knowledgable than me may disagree, but i would be concerned about fumes, just think about a hot day with your defender park'd up and the fuel and tank getting all warm and the preasure building and expelling into the cab, if however there is a non-return valve you are putting your faith in that little part, just a thought.
Couple of fumes - open windows for a minute and all's fine again
![]() Series III 1973 - going strong |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
You can light a match on the tube and nothing would happen. It is more dangerous to blow a match with a fart. Puma 110" SW
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
You can light a match near a battery air vent - doesnt mean the fumes wont kill you ![]() |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Very true - Fumes are carcinogenic. I'd route it outside if you can. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
