Home > Td5 > Radio fitment |
jof33 Member Since: 26 Nov 2011 Location: Oxfordshire Posts: 53 |
Does have a rubber plug about half the size of your index finger(ish). Dont know a part number though?!
17th Jan 2012 7:42am |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
The rubber plug is part of the radio not the land rover so a part number will be difficult to get. Have you fitted the cage at the front properly and bent the tabs up to keep it in place? My radio in my TD5 is rock solid and is a JVC unit too.
Pete. |
17th Jan 2012 10:25am |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 |
Mine is an 04 model and the part that shakes loose is the middle bit where the radio fits within the larger console, if you know what I mean. The cage tabs are bent to hold the radio tight within the middle bit but this, itself, is not very secure within the console outer. There are a couple of springy bits of wire on the middle bit that don't seem to do a lot.
Any idea how your two parts fit together? Oh and I might be able to get a rubber bung from Halfrauds or some other radio suppliers. Thanks for the help. Tony |
17th Jan 2012 1:09pm |
Oh i know what bit your on about now. Mine just clips in and is quite secure. Maybe it has been pulled out in the past and a bit of it broken?? Maybe try glueing it in as its a bit that doesnt need to be removed for any reason.
And yes you prob can get the rubber bit from Halfords. Pete. |
17th Jan 2012 7:33pm |
Yeh, probably will glue it. Seems a bit odd that there isn't a way to properly secure it or beefier clips Just got to find a proper bung first.
Cheers, Tony |
18th Jan 2012 7:21am |
