![]() | Home > Technical > Handbrake / brake fault light |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
...the red one on the dash. What is it connected to? Obviously the handbrake, but what else?
Recently mine has started to flicker occasionally. This seems most prone to happen when going downhill or turning right (!). Turn left, go uphill or boot the accelerator hard and it goes out. Doesn't seem to be related to whether I'm braking or not, which makes me think it's a sticky handbrake switch. Is this under the driver's seatbox? |
Brake fluid level. Darren
Thanks, will check that one tonight. Would make sense in terms of how the light is behaving, fluid sloshing round etc.
Brake pads could need replacing...if your fluid is low check them NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
