Home > Wheels & Tyres > Rear wheel carrier |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Aren't Mantec ones "approved" by LR?? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
24th May 2007 1:14pm |
badlands Member Since: 25 May 2007 Location: Darkness on the Edge of Toon. Posts: 8 |
Yeah, Mantec seem to be the dogs bits. Bruce Springsteen & the E Street Band
25th May 2007 7:58am |
ronp Member Since: 29 Jun 2007 Location: 🌲North Yorkshire🌲 Posts: 43 |
MANTEC, any day!!
30th Jun 2007 10:11pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
I'm more tempted by the ones that just fit to the rear crossmember and open indepentantly. Frogs islan do one and also BOAB import one.
Does mean you need to open it before the door though, but they are so well engineered. I'm finding that the weight of the wheel stops the rear door staying open if the Landrover isn't on flat ground - which can be painfull. |
12th Jul 2007 12:52pm |
banstock Member Since: 04 Aug 2007 Location: berkshire Posts: 10 |
I went for the Scorpion Racing one with the HiLift holder
Had it about a year and its still as good as new. |
4th Aug 2007 11:56am |
robbeaumont Member Since: 18 Jun 2007 Location: Oxfordshire Posts: 9 |
Safari equip do one as scorpion racing but cheaper Made in the same factory!!!!!!
9th Aug 2007 10:46pm |
TREX Member Since: 17 Aug 2007 Location: ALICE SPRINGS Posts: 1 |
If someone has designed one for a 130 someone let me know!!
17th Aug 2007 10:47am |
See above posting
17th Aug 2007 1:15pm |
Mossy2 Member Since: 17 Dec 2007 Location: Chester Posts: 5 |
Hi I have a Boab (Kaymar) wheel carrier on my 110, and the build quality is just brilliant. Although as previously stated you do have to swing the wheel away before opening the rear door which can be a pain.
There is a small locking pin that holds the wheel in the open position, also for added security you can lock the wheel to the carrier using a standard padlock. |
17th Dec 2007 2:59pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I have fitted the hinged type wheel carrier but as I have bigger wheels and tyres than standard. I think because of this its causing the carrier to loosen then the wheel rattles or wobbles. So I am looking to fit one of these swing away type carriers Is there any chance you can bring your 110 down to Boughrood to show me this wheel carrier In return you can spend the day 4x4ing |
22nd Jan 2008 6:46pm |
Hi Andrew sounds like a deal, Can't give an exact date yet but i'm sure we can arrange it. But in the meantime to can see more details here
http://www.boab.biz/Pages/Kaymar%20Spare%20Wheel%20Carriers.htm As this is my actual car & carrier, and as you can see it should take most sized wheels with out any problem. |
25th Jan 2008 1:13pm |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 |
Is that u Mossy did not know u had a Defender
26th Jan 2008 5:58pm |
I'm his ickle brother hence Mossy2.
28th Jan 2008 10:25am |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 |
Aha! Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
28th Jan 2008 10:26am |
