Home > Td5 > Hi/lo lever jammed? |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2658 |
Using mole grips you'll have to use a fir amount of force to engage. If you look at the length of the levers and where the fulcrum is you'll realise how much force you need.
It does become a bit of trial and error when refitting the levers if you haven't marked them before removal. Keep at it and you'll soon realise which way round it all goes 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
12th Jan 2012 9:44pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8006 |
auto box is not in Park is it?
handbrake on with difflock in? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Jan 2012 9:51pm |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 |
Before t/box, gearbox and engine were joined, the lever moved easily with mole grips. I'm thinking it's just cogs not lining up? Engine is not startable yet, so may have to come back to this. 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
12th Jan 2012 10:05pm |
Why would auto being in park make a difference? I can't start engine yet as ecu has to be matched with injectors etc. 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
12th Jan 2012 10:08pm |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 728 |
My 50th auto had to be in neutral to move the hi/lo lever. Formerly mao99999
16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
13th Jan 2012 7:49am |
Same on my 300 Auto, has to be in N to move hi/Lo lever 110 D250 SE HT
13th Jan 2012 9:16am |
I haven't got the electrics wired up yet.
Problem was the bolt going through from the front holding the t/box to the g/box near the hi/lo lever was too long and fouling the gears inside! Had not realised one bolt was shorter than the others. Could have been nasty if I had tried to drive it to free it off.... 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
13th Jan 2012 12:56pm |
i was only trying to help you take them out of park to help with gear alignment rather than having it locked in one place. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
13th Jan 2012 10:22pm |
