![]() | Home > Off Topic > Posting links |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
You insert the actual URL (so www.google.co.uk or whatever) after an equals sign in the square brackets, then close the brackets and put the text you want to make clicky. So like the following but with square brackets not round ones:
(url=www.google.co.uk)Clicky text here(/url) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17566 ![]() ![]() ![]() |
Select the whole of the word you want to make into the link, then click on the URL button. This will put the "[url]" and "[/url]" tags round the word. Now edit the opening tag (the bit inside the first set of square brackets - make sure that the brackets are still there) to be in the format "url=http://www.defender2.net/forum" and that should do the trick (I can't put the square brackets in the bit in this post without it becoming a link and hence invisible, and obviously the link to this forum is just an example, insert your own link in its place). Simples! It's actually harder to get all these tags and things into a post in a visible format than to put the links in. HTH PS 2.6khz, you just beat me to it! ![]() |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
google
By jove! I think Ive got it ![]() So just put an '=' before the first closed bracket, followed by the link. Then inbetween both sets of brackets type the word you want to use. Been baffling me for months that one ![]() Thanks to you both ![]() |
Just need to fathom out how to 'multi quote' other posts now
Hit quote on the first post.
Copy the entire text. Return to the thread and hit quote on the next post. Paste in the text from the first post. Edit as required and Bob's your mothers' brother. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Ooohh, a bit like this then ![]() ![]() ![]() |
Its all about asking questions others daren't ask
![]() Nice one Warpig, everyday's a school day! |
Your right GREENI. Different forums have different ways of doing things, wasnt sure how to do it on here. ![]() |
