Home > Td5 > Radiator connections
Arbman Al
At the bottom right corner of the TD5 rad there is a stub into the plastic surround. What should be connected to this, as I don't seem to have any pipes left over??
Cheers...Al 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #114339 11th Jan 2012 5:36pm
bell-auto-services
Do you have a picture ?
Post #114340 11th Jan 2012 5:41pm
Martin
Site Admin
There should be a pair - one front and one back. They are to connect to the fuel cooler unit.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #114343 11th Jan 2012 5:53pm
Arbman Al
Can't do pics onto the forum from my iPhone.
It's on the drivers side bottom right hand corner. The stub is about 1/2 inch dia and is close to the mounting foot. 1996 Defender 130 converted to TD5 and auto
Post #114344 11th Jan 2012 5:54pm
landyman40
United Kingdom 2003 Defender 110 Td5 XS CSW Zermatt Silver
hi changed my td5 anti freeze this weekend noticed the same thing. its a blank port used on earlier models apparantly as the coolent pipes were slightly different if needed just bore it out . mines running ok with anything connected to it.
Post #114366 11th Jan 2012 6:35pm
landy andy
Email me the photo if you need, a.russell@virgin.net , and I will post for you
Andy
Post #114452 11th Jan 2012 9:45pm
landy andy
Post #114453 11th Jan 2012 9:48pm
Arbman Al
Found this: http://www.lro.com/forum3/viewtopic.php?f=19&t=22803
Seems to explain. I'll check in the morning that it is blocked off.
Post #114461 11th Jan 2012 9:59pm
