Home > Puma (Tdci) > Dammit! Bust my rear wiper :(
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Fitted 265/75 16s on tomb raider boosts to my Landy and didnt think to check wiper clearance, first day I've needed it today and I've turned it on and jammed it Sad I've loosened the nuts of the wheel and returned it to the stop, but how do I go about adjusting the wheel out? It's dark and hammering down now so I can't really see, but I'm assuming there's adjustable stops behind the wheel? Or do I just use the old method of an old standard wheelnut used as a spacer?
Thanks! 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #113849 9th Jan 2012 8:08pm
I think you'll find that using spacers (of some sort) will probably be your answer Thumbs Up
Post #113857 9th Jan 2012 8:20pm
Jimbob
Old wheel nut it is then Smile cheers!
JW how do they do it from the factory then? Cos 265/75s are an optional extra aren't they? 2009 Defender County Hard Top (gone 😞)
Post #114059 10th Jan 2012 1:58pm
landy andy
There are large flat nuts fitted to each thred, I put 10mm spacers behind these, but could of just screwed them out a bit.
Andy
Post #114067 10th Jan 2012 3:34pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Best bet is to buy some washers and pack it out a bit. Put 1 extra washer on the top stud and you will need to pack it out less.
Pete.
Post #114085 10th Jan 2012 5:27pm
