Home > Technical > Anyone fitted pulse dampeners to their Puma's fuel rail? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
As pointed out by a fellow landyman here in SA:
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Jan 2012 10:43am |
Well, this friend of mine seems to think not. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Jan 2012 12:52pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Edit:
The puma does have the option to monitor fuel pump pulse widths as there are sensors to report this to the ECU. And after checking my scangauge in the defender I had already set up the xgauges to monitor these readings so I would think the ECU does this as standard on all Pumas. Xgauge codes to monitor: Fuel Pump Pulse Width (Bank 1) TXD: C410F1221141 RXF: eBay Item No. 046205110641 RXD: 3010 MTH: eBay Item No. 000200010000 NAME: FP1 MEASUREMENT UNITS: Counts Fuel Pump Pulse Width (Bank 2) TXD: C410F1221142 RXF: eBay Item No. 046205110642 RXD: 3010 MTH: eBay Item No. 000200010000 NAME: FP2 MEASUREMENT UNITS: Counts Brian. |
9th Jan 2012 12:54pm |
