Home > Td5 > Wastgate contorl valve/module |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
The modulator is only fitted to Discovery Td5, not Defender.
8th Jan 2012 3:05pm |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 |
Cheers. Thats one less thing to buy then Where does the pipe that goes onto the wastegate connect to then? There is a T in the brake vacuum pipe that does not have anything connected to it, is it to here? 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
8th Jan 2012 4:02pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 |
It goes to the intercooler metal hose that with rubber comes from the turbo to the intercooler UK passenger side.
8th Jan 2012 4:39pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 |
As Pete said,
The T in the vacuum pipe is for the EGR Valve I would think. Andy |
8th Jan 2012 4:42pm |
I may be being thick here but I am pretty sure (until I have a look tomorrow) that the two pipes on the egr valve go to the modulator on the wing (two solenoid modulator). I can't see where a pipe from the 'T' in the brake vacuum servo pipe connects to. Microcat and the manual don't shed any light on this matter... 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
8th Jan 2012 7:00pm |
The vac pipe on the brake pipe has a T near the alternator but landrover do do a pipe without the T fitted.
8th Jan 2012 7:44pm |
in the picture you can see two red arrows, the T is behind the top red arrow hidden by the larger black pipe. the bottom red arrow is what has been taken off the T. From the T it goes to the solonide on the inner wing.
Dont worry about it, blank the egr valve and vacuum hose and remove the vacuum pipes and solonides totaly Click image to enlarge |
8th Jan 2012 7:53pm |
Thanks again Pete Is the connector a little right angled boot, as I found one lying on the floor the other day before the engine went in, so hopefully will find a pipe with no connector on the end.... 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
8th Jan 2012 8:14pm |
no problem, yes its the right angled boot as seen on the end of the lower red arrow.
PEte |
8th Jan 2012 8:18pm |
Looking at the pipe work for the egr modulator on the wing and I have found this:
The two clear/white tubes are connected by a joiner and then the one white tube has been plugged into a joiner that has two green tubes coming into it from the modulator. The 't' on the brake vacuum pipe is unconnected to anything. Two blue tubes go to the egr valve as normal. Is this someone's attempt at by-passing something? Should it be connected up as per the Haynes manual? Cheers...Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
10th Jan 2012 9:20am |
I would remove the egr valve, and all the pipe work completely.
Then get vac hose that does not have the "T" in it. Andy |
10th Jan 2012 3:29pm |
I probably will eventually, but for now I just need to get it connected up so that I can get the engine running asap. Can I leave it like it is (done by previous owner), and blank off the T in the servo pipe? 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
10th Jan 2012 4:44pm |
Yes, most do just that. It is only the nicer kits that come with new vac hose.
Andy |
10th Jan 2012 5:22pm |
Thanks Andy. Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
10th Jan 2012 7:28pm |
