Home > Puma (Tdci) > Part number ?
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Part number ?
What's the part number for the air mass flow meter for the puma in the hose to the turbo ???
Regards Steve [/i] 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #113269 7th Jan 2012 5:52pm
MK
http://www.defender2.net/forum/topic5282.html Puma 110" SW
Post #113286 7th Jan 2012 6:09pm
ickle
Hi Steve,
I swapped mine for a new one last summer as I suspected it was faulty - not a bit of change, disconnected the egr at the valve, performance returned and I live with the yellow light until I can get my act together and get a remap.
Keith
Post #113292 7th Jan 2012 6:30pm
big steve
Yer problem is that mine has a temperature probe problem so I do need a new one
Regards steve 2015 2.2 tdci hardtop xs
Post #113295 7th Jan 2012 6:42pm
big steve
Some onmust know it 2015 2.2 tdci hardtop xs
Post #113660 8th Jan 2012 10:27pm
bell-auto-services
MHK501040
Pete
Post #113665 8th Jan 2012 10:34pm
ickle
Steve,
Firstly have you got one or do you need my spare?
Secondly, you say you have a temp problem, have you got a scangauge fitted and if so has the inlet air temp gone wrong?
Cheers Keith
Post #113968 9th Jan 2012 11:18pm
Lorryman100
Remember as well there are two separate sensors in the MAF. One deals with the Ambient air temp and the other is used by the EMS to indicate air flow to be used in fuelling calculations by the EMS. So you can theoretically have a working Hot film sensor feeding the correct info to the EMS but have a faulty AAT which doesn't really affect the fuelling calculations. On the other hand a knackered Hot film sending spurious readings to the EMS causing high fuel use and other issues can be dismissed by some as the AAT is working so that must mean the MAF sensor is working fine when it is not. Wink
Brian.
Post #113970 9th Jan 2012 11:26pm
