Home > Puma (Tdci) > ScanGuage won't reset engine light
Kez
Isle Of Man
Have just had EGR valve replaced with a new one bought from local mail dealer, had t fitted by local garage as he's done a few bits before. Just got car back, go to reset engine light and it just keeps saying 'not ready'. So hit the force clear button, get the 'codes cleared' message. Turn on engine and its still there.
Listening to valve its doing it job as far as I can tell (you can hear the usual cleaning cycle) so really not sure whats going one Shocked
Post #112553 5th Jan 2012 6:23pm
Lorryman100
Unlike a proper diagnostic tool the scangauge must show --Ready-- before a valid DTC scan and reset can be carried out, as this indicates that all tests have been completed since the last DTC reset. This then shows that a valid test cycle has been carried out on the OBD. If --Not Ready-- is displayed, the vehicle hasn't completed some test cycles. It could take up to several days after codes are cleared for the vehicle/scangauge to be in the --Ready-- mode again. Thumbs Up
HTH Brian.
Post #112627 5th Jan 2012 8:43pm
pom
Lorryman100 its time to confess, your the head of software at LR. No way you could know all this shizzle otherwise.
How's the staff discount ? Mr. Green
Pom
Post #112631 5th Jan 2012 8:45pm
Kez
Isle Of Man
Bow down Thank you Lorryman100
Post #112632 5th Jan 2012 8:48pm
Lorryman100
@Pom No, afraid not. I just remembered it from when I read the instructions when I first got mine. Thumbs Up
Post #112635 5th Jan 2012 8:50pm
Kez
Isle Of Man
instructions Shocked
Post #112641 5th Jan 2012 8:54pm
BigRuss
Yes that's right most items come with instructions, or where you wondering why all these companies give toy free coasters with every product Thumbs Up Russell
2011MY 110 XS USW Black
Post #112712 5th Jan 2012 10:09pm
Kez
Isle Of Man
Can you tell me where I can find the ones for my wife, looked everywhere and nothing works in a logical way!
Post #112716 5th Jan 2012 10:14pm
Kez
Isle Of Man
Ok, its now a few days and still cant clear light - no faults showing, even doing a 'force clear' does nothing, local independent garage looked at it and they also could not see any faults - really don't want to have to resort to booking it in at Main Dealers but not sure what to do Big Cry
Post #113195 7th Jan 2012 1:01pm
Lorryman100
I did the write up on some new remap files on Wednesday and cleared all fault codes from my Puma with the MSV, I then checked the scangauge today after getting an email notification of your post Kez, and it is still showing not ready.
HTH Brian.
Post #113313 7th Jan 2012 7:39pm
Lorryman100
The check engine light is the MIL, yes? That only illuminates when a tested DTC is logged. The scangauge does not show all tested dtc's as per the list on their website but the indie should have checked and cleared all DTC's after fitting the EGR valve. Do you know if he tried to do this? The fact the MIL stays Illuminated even after a new EGR has been fitted would have me checking the EGR plug as well as the adjacent MAP sensor incase anything was knocked when the EGR was being removed/fitted. Do you know what diagnostic gear the indie uses?
Brian.
Post #113318 7th Jan 2012 7:55pm
Kez
Isle Of Man
Checked all connection and all fine, took it to another indy who has vastly superior diagnostic kit and right software for the Puma (my local chaps was a very basic unit that by his own confession was a bit old). Found one fault (maf sensor - again) and cleard it, light now out and all fine...except, when I check with Scanguage it still says not ready - how weird is that Shocked
Post #113723 9th Jan 2012 12:10pm
Lorryman100
It will show not ready again because you just had the maf fault cleared with diag gear. So it goes through the test cycle afresh.
Post #113724 9th Jan 2012 12:13pm
Kez
Isle Of Man
Thumbs Up good point, stupidly assumed t was still the old message not a new one - phew
Post #113731 9th Jan 2012 12:32pm
