Home > Puma (Tdci) > wtd auxillary lighting loom and plug
Page 2 of 2 <12
Lorryman100
Post #113181 7th Jan 2012 11:23am
Glynparry25
Since I had my bonnet and dash off today for re-sealing all the electrical wires I have took a few pictures:
Looking from the front of the vehicle route the wire down the right hand wing using the clips.
Where the cable splits, one end goes down (I cable tied it to the group of cables going down to the pass seat box). The other one can neetly go through the bulkhead at this point (top blanking bung):
Inside the set box, just neatly secure it to the side wall and connect to the battery:
Behind the dash connect the cables to the 'Rear heated screen'? plug:
Single wire goes to the instrument cluster plug:
Hope this helps a little. Where the wires connect to was the more confusing thing about the instructions as they were in black and white.
Glyn Dog :sheep:
Post #113301 7th Jan 2012 6:49pm
LR90XS2011
thanks again to all those that have responded
I have now printed off the instructions and Glyn's photos and will be going for the loom fit tomorrow (whilst the mrs is at work), will let you know how I get on. I am now just waiting for the Lamp Bezels off NAK and Ive got everything I need to complete the job
Update wiring loom all fitted took about 3.5hrs in total bit nervous removing the instrument binnical etc but all appears to still work ok and the auxillary light switch appears to operate correctly have not tried it with lamps yet but the relay is pulling in and out as it should.
Now got to drill 4 off 59mm holes in my bumpers make up some looms to the Ring Driving lamps from the land rover plugs (need to get some plugs of the right type) fir the bezels when they come and fit the lamps. DEFENDER 90 TDCI XS,
Post #113316 7th Jan 2012 7:48pm
Page 2 of 2 <12
