![]() | Home > Off Topic > Anyone have Math ? |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Is the answer 12ft. By using inscribed circle law and squaring both sides then using the Quadratic formula that's what I get?
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Isn't this a trick question as the dimension at Y is an unknown amount more than 3ft (Grrr, Imperial) it just so happens a 3ft circle fits in the void. We therefore only know one measurement and can't work out the vertical or horizontal.
Sine, cosine, tangent? Forgotten which is which. B at GCSE maths 16 years go (in Worcester as it happens, Pom). |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
11.8877777777
I get 12' doing a quick scale drawing, that would be close eniough for me, well within any tolerence levels I work with
Isn't it a kiss?
Pom - you tell me your answer and I'll tell you if it's right
![]() But shout it at them in German because life is also terrifying and confusing... |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
I get 12' too. As Lorry says, as the three sides of the triangle form three tangents with the circle, you can treat it as an inscribed circle (or incircle).
Pete |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
turn the circle into a box, you know its 3 ft.
then you end up with 2 x right angled triangles and a box easy from there on in.....think this was a starter question when i did my HNC some time ago. heads full of mantec storage and shower cubicals at the mo! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17566 ![]() ![]() ![]() |
There are two possible answers mathematically, x=12 or x=3.5
If we consider y to be the length of the short side, we know that: (x - 1.5) + (y - 1.5) = 12.5 (since chords are of equal length) => x + y = 15.5 which we will call eq1 We also know that x^2 + y^2 = 12.5^2 (Pythagoras) which we will call eq2 Squaring eq1 and subtracting eq2 gives us eq3) 2xy = 15.5^2 - 12.5^2 => 2xy = 84 considering eq1 again: x + y = 15.5 => y = 15.5 - x Subsitute for y in eq3: 2x(15.5 - x) = 84 multiply out: 31.1x - 2x^2 = 84 therefore 2x^2 -31x +84 = 0 Solve the resulting simple quadratic equation: x = (31 +- sqrt[961 - 672])/4 = (31 +- sqrt[289])/4 = (31 +- 17)/4 So two solutions, either x = 12 and y = 3.5 or x = 3.5 and y = 12 There may be a simpler way, but I can't see one at the moment! |
The easiest way to find x is to program the diagram into AutoCad and it works everything out for you.
![]() ![]() Or you can go down the maths route: ![]() Click image to enlarge |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
my partner and i were feeding our twins last night. they both take 150ml.
my partner commented that this volume does not seem to have increased over the past few weeks even though they are growing. i asked her to consider this volume as a sphere and compare it to the size of their abdomen's. what size is the sphere? ![]() no internet or reference books allowed!!! |
Come on then Pom, what is the answer?
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 ![]() ![]() ![]() |
Which size: radius, diameter, volume? ![]() ![]() ![]() |
