![]() | Home > Maintenance & Modifications > Wet feet cured! |
Just for info, the disgusting sleet here has provided perfect conditions for wet feet
![]() Slush backed up on the lower windscreen gutter has finally ensured a steady flow of water inside at the lower left corner of the windscreen. Will now seal the rubber a.s.a.p. as recently discussed. Incredible that the LR water ingress manual doesn't even mention this point as a problem spot ![]() Incidentally, is there a DIY improvement for the lower windscreen gutter - mine is almost blocked off by the hinges both ends? Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
