Home > Maintenance & Modifications > Wading kits? |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
No there is no LR kit for the 2.4 or 2.2 because LR says you cant wade over the hubs. In fact I think they say 50 mils is the max. Saves on all those warranty claims for carpet and batteries
gwyn lewis makes one but do bear in mind that to get breathers on everything means that you have to drop the gearbox. Bear in mind that unless you plan to sit in water for quite a while you really dont need breathers - I've never had them and been in all kinds of water, but never had any issues with diff oil or gearbox oil or anything similar. I would advice to make sure you seal the battery box though with RTV paying particularly attention to the cable exits |
5th Jan 2012 10:00am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8032 |
50mils! - 500mm you mean although as you elude to 50mm may be more suitable!
you can extend them all your self. just get some 6mm pipe with male to male push fit connectors and extend them to where ever you wish. personally for anything i intend to wade with i extend both axles, timing cover, t box, autobox (one front and back to allow for sat on slopes). Battery box i tend to leave open, it will get in anyway so may as well leave just as quickly. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
5th Jan 2012 10:55am |
