Home > Puma (Tdci) > Engine Rev on its own |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Not sure about this - I looked at the technical bulletin and it suggests that the part number for the new and old clutch assy are the same. I think later ones have uprated springs (which you can only tell if you have it in bits) One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
21st May 2009 12:45pm |
philp Member Since: 21 Oct 2008 Location: surrey Posts: 22 |
On the back of the Clutch master cylinder is a switch; nothing fancy... just something that makes or breaks an electrical circuit when you press the clutch pedal.
There are two wires connected to it. If your car "Revs on" unnecessarily when changing gear, if its a puma join the wires together using a "jump lead" If its a Td5 just pull the connector off. This disables "Surge Damping" which can be problematic, this will just leave you with the decision to control the engine speed when you change gear... just like the old days. And if you prefer how it was beforehand disconnect it or reconnect it! Anyone else know any better? I have had no problems with either the Td5 or the Puma after I have done this when the surge damping has started playing up. I know it shouldn't have to come to a DIY fix but I do understand process and control systems and I do understand Defenders. |
21st May 2009 10:34pm |
