Home > Maintenance & Modifications > TDi conversion: Costly? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
I would say £2500 200tdis getting a bit thin on the ground though
31st Dec 2011 8:28pm |
westfield106 Member Since: 29 Dec 2009 Location: leeds Posts: 58 |
300 tdi would be a cheaper option due to avaliability !!
Although these are creeping up in value. Any specialist should be able to carry this out quite easily !!!! |
31st Dec 2011 8:41pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5012 |
Turners Engineering (sell remanufactured TDi's) were suggesting a couple of years ago that the 300 was a better bet as 200 parts were difficult to get hold of. Think they were talking about the heads in particular!
31st Dec 2011 10:43pm |
Simmonites?????
http://www.simmonites.com/Vsale.htm They'll build you what you want on request. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
31st Dec 2011 10:53pm |
