Home > Puma (Tdci) > scuffing noise on switch off
YORKSHIRELAD
Hi lads. My puma's engine makes a short grating noise when I switch it off.I can't really describe it but it's a kind of scuffing noise for a second before it comes to a complete stop. Is it normal?. Thanks,
Richard 1963 Series 2A truck cab
2008 110 SW
Post #11080 19th May 2009 11:58am
Eduardo
Same of mine.
2 or 3 scuffs for a second or 2, Looks like a giratory piece that don't stop inmediately and continues to work by inertia. I didnt care too much about it, but it is good to know that other have the same.
Cheers Eduardo
Post #11081 19th May 2009 12:32pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Same sort of noise with mine, together with some heavy shuddering. I'm with Eduardo. Too many other things with it to worry about.
Bosun.
Post #11083 19th May 2009 1:57pm
bustduster
Same with mine. Assumed, as it is not intermittent, it is normal. Not had an explanation as to what it is. Another noise to consider is the one that sounds like a brief starter motor noise just after engine fires when starting up. Informed that it is the ABS modulator and is normal, although the odd time it doesn't occur.
Post #11084 19th May 2009 2:09pm
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
Mine too but I try to start and stop with clutch depressed - read somewhere it was better to do so.
Post #11088 19th May 2009 3:17pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Nothing to worry about. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #11090 19th May 2009 4:13pm
YORKSHIRELAD
Thumbs Up Cheers lads.
2008 110 SW
Post #11102 19th May 2009 6:10pm
dgardel
Italy
Ehmm.....
have you listen a new transit van????????????????
is the EGR cleaning cycle, for remove particulate from the tappet valve base Rolling with laughter Rolling with laughter Rolling with laughter
Post #11109 19th May 2009 9:15pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Have the same noise with mine, put it down as a quirk of the Lanny. Cogito ergo sum
Post #11112 19th May 2009 9:38pm
Scallops
Australia
It's the fuel pump stopping - normal
Post #11113 19th May 2009 9:38pm
dgardel
Italy
May be I must increase the font size one more time????? Whistle Mr. Green Mr. Green Mr. Green Mr. Green
Post #11114 19th May 2009 9:41pm
MK
I think these are two different things. Once the engine is at full stop, I get 3 double clinks. Puma 110" SW
Post #11115 19th May 2009 10:14pm
alantd
That's you taking the key out Whistle One that started out as a 2.4 TDCi 110 XS
Post #11116 19th May 2009 10:16pm
MK
Can`t be. They are of rubber so they don“t brake inside as it is LR made. Puma 110" SW
Post #11117 19th May 2009 10:23pm
