Home > Maintenance & Modifications > Rear door gas strut |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
ME ME ME !!!!!!! Save me one, will phone later [working atm] Guns and Landrovers .... anything else is irrelevant. |
30th Dec 2011 10:52am |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 |
Any pics of these fitted to a puma?
30th Dec 2011 11:10am |
Previous owner riveted a nice loop thing on the outside and a bar fitted to the top of the inside of the door on mine!! Looks proper !!
30th Dec 2011 11:12am |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
did notice the gate latch! i'm ordering some bits from Leeds so get it sent together? save postage? and don't forget the rear thingy |
30th Dec 2011 11:14am |
Ha, it NICE ain't it!! Lol yeah wouldn't mind seeing one fitted to see if it reduces clearance?!
30th Dec 2011 11:17am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Hi Jammer, am not sure what you mean about reduced clearance.
Photo below, supplied by one of our customers shows final view before rear door card goes back on Click image to enlarge The bracket mounted on wheel box is moved out by about 6mm. Door card requires no trimming. HTH Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
30th Dec 2011 2:56pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
So how do you get over Defenders with rear draw systems as that image shows that the door does not open far enough
30th Dec 2011 3:22pm |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
it does, there is no difference between the oem and the strut. Pom |
30th Dec 2011 3:37pm |
Just ordered ... nice chat with the luvverly Barbara Guns and Landrovers .... anything else is irrelevant. |
30th Dec 2011 5:06pm |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
you can use ''spacers''.
i use 5 in wheel arche and 2 at door my door opens as before gas strut. it is obvious http://www.lrgreece.com/phpBB3/viewtopic.php?f=20&t=238 www.newfoundland.gr |
30th Dec 2011 5:18pm |
Ken does raise a good point in the compatability between different items of after market equipment.
Not all aftermarket gear will work well together. Just been outside and open rear door of red 110. Standard door stay, chequer plate to inside of door BUT no cover over door stay. Mobile Storage drawer opened no problems. The black 110 has a post 2002 door stay fitted with standard door card fitted and a Mobile Storage drawer. Open the door, if the drawer is opened it might just catch the door card cover where it goes over the original door stay. There is movement on the drawer runners, drawer moved to right on opening it just catches the hump on door card. Open drawer to the left it clears hump in door card. If it bothered me I suppose I could move main bracket sideways to the left and door would open further. Would it be compatible with all makes of drawer systems? That question I can not answer but I would think so. Brendan PS Down to one now until next week |
30th Dec 2011 5:35pm |
Nope looks good to me, hadn't thought where it connected from but all clear now!
30th Dec 2011 8:28pm |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
FYI
Since fitting my strut to my 2010 puma with mss draw, the draw does clash with the rear door card, I have to push the door open a bit more, which I believe has now bent the strut a bit Tack |
30th Dec 2011 11:37pm |
Hi Tack, you should have let me know that you had a problem with the door gas strut. If it has bent we will replace it of course, no problem there. You have a pm.
Brendan |
31st Dec 2011 10:19am |
