![]() | Home > Wheels & Tyres > Help!!!Wolf Wheel Problems |
This has come up from time to time across quite a few forums. As has already been mentioned some come from the factory with HD rims and standard length studs meaning a couple of threads of the wheelnut show. I've run them like that on several Defenders in the past without issue and have a set of HD rims for winter use fitted now. Steve.
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
Exactly the same on mine. I queried it when it was new, and that how the factory supply them. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Not so - the studs only secure the wheel against the hub - whilst it is important that they hold tight they do not need to protude as far as the end of the bolt. The weight of the wheel is taken by the flange of the hub fitting in the centre of the wheel, not the studs, Series vehicles often had shorter studs which did need replacing for wolf rims which is where the confusion comes from. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
