![]() | Home > Maintenance & Modifications > Headlight half bowls - cant find any for my XS |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
i gave up quiet some time ago odin. So back to my original question about owning an XS! |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 ![]() ![]() ![]() |
Think this is what you are looking for ?
http://www.ebay.co.uk/itm/2-x-HEADLAMP-BOW...914wt_1066 Regarding the Head lamp leveling switch, it will only be present on "Car" derivative models, i.e. Station wagons, commercial variants are not required to be fitted with Head lamp leveling. Richard Either a 90, 110 or 130. Discovery 5 |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
http://www.wipac-aftermarket.com/uk/acatalog/Components.html Marco
Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Without Headlight adjuster:
http://www.ebay.co.uk/itm/WIPAC-Headlight-...1984wt_750 Or buy the complete kit: http://www.ebay.co.uk/itm/7-WIPAC-CRYSTAL-...1485wt_750 And the location of the adjuster is here, excuse the pic as this is the only one I have showing the location of the adjuster: ![]() Click image to enlarge HTH Brian. |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 ![]() ![]() |
Thank guys, much appreciated, for interest according to bolt on bits and I quote:
Wipac do not supply a direct kit for Land Rover with headlamp levelling. We can supply complete half bowls with motors but you do not want these so you have to work with what we have listed. I will repeat myself and state we do not have a kit to fit your land rover you will have to buy the parts you require. Here are the items numbers eBay Item No. 220689821151 Just black bezels eBay Item No. 230712762232 Stainless rim to prevent rusting of bezel does not come in black eBay Item No. 230536950031 Just Black half bowls to use for parts (throw plastic parts away) ![]() eBay Item No. 230716865767 Plastic half bowl for levelling models ![]() |
