Home > Maintenance & Modifications > Smallest steering wheel w/ instrument visibility?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all...
Looking at fitting a smaller steering wheel, as my wife struggles to drive the 110 with the factory bus wheel.
What is the smallest size that one could use while still allowing for instrument visibility and signal cancelling to work?
Post #110266 27th Dec 2011 7:43pm
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Just fitted a momo Nero (350mm). Speedo is fine, I lose a little bit of the tacho but as my wife sits closer she says she can see all of it.
Stu
Post #110268 27th Dec 2011 7:51pm
K9F
Hi Eutek,
With the right boss (not Mrs E, Laughing ) cancelling will not be an issue whatever the size. With respect to instrument visibility it depends on driving position and whether you are prepared to alter position to regain visibility. I am wherever possible a straight-armed driver and with anything smaller than 15" I lost visibility of between 10 and 12 o'clock and 12 and 2 on the tacho and speedo respectively. With certain wheels you also get the choice of 'dished' or ''flat' which can also have a bearing on driving position and visibility. As I did, I would strongly suggest you 'try before you buy' if possible as nobody can decide for you or advise properly as it's a 'personal choice' thing dependant on circumstances....
Not much help sorry! Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #110278 27th Dec 2011 8:38pm
