Home > Maintenance & Modifications > DIY (Defend It Yourself) advice please...
ZeDefender
I consider myself quite handy at most things but I am humble (and clever) enough to know I can always learn. So here's my question:
I just got some Safari security grilles for rear windows of the 110 (thanks again Leeds) and I'm about to brave the elements and fit them Very Happy
Normally I would just drill through the skin using the holes in the mounting brackets as a guide. However, the grilles are steel and I don't want to damage the powder coating inside the holes before I rivet them on i.e. bare steel + aluminium rivet = Shocked
Any suggestions for a reliable way of marking/drilling the holes without damaging the grilles? Usually when I mark/drill, holes tend to be "a bit off" Sad
I'm sure there is probably an obvious/clever solution and this seems like a good place to ask Thumbs Up
Also, the mounting brackets have holes on one side (top/bottom) and slots on the other. Is there a particular reason?
Matt Tell someone you love them today because life is short.
Post #110244 27th Dec 2011 6:43pm
T1G UP
masking tape the area so you don't scratch anything. line up the grills and with a pen mark the holes, remove the grill and drill, remove tape, inset rivnet and fit!
Post #110245 27th Dec 2011 6:48pm
ZeDefender
Never seem to get the marking right (God knows I try!) - do you just put a dot in the middle of the hole or draw round the rim)?
I know it seems a daft question but if I cock up even a bit, I'll have a leaky skin... Tell someone you love them today because life is short.
Post #110246 27th Dec 2011 6:50pm
T1G UP
well it depends on the size of the hole to the size of the pen! either way the middles best.
get someone else to hold it still
Post #110248 27th Dec 2011 6:52pm
ZeDefender
Cheers.
Any idea why there are slots on one side and holes on the other? I thought it might be to allow for vertical error, although that would suggest drilling inaccuracy which could also make horizontal error Sad Tell someone you love them today because life is short.
Post #110249 27th Dec 2011 6:56pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
apologies if you know this, don't mean to be patronising or teach the preverbial grandmother to suck eggs........can i suggest that after you have marked up the drill holes you use a centre punch [or large nail] to 'mark' where you want to drill as it will help the drill bit bite, also use a smaller drill bit as a pilot hole before you use the correct size drill bit.
good luck BM52
Post #110251 27th Dec 2011 6:58pm
ZeDefender
Embarassed Didn't think of that - usually drill pilots and upsize just for large holes (e.g. through plate).
At least if I drill really small pilots I can place the grills back on to see if I'm about to screw up really badly Thumbs Up
Cheers all
Post #110252 27th Dec 2011 7:02pm
K9F
If you 'wet assembly' the rivnuts (by using Sikaflex or another suitable sealant) it will not matter if the paintwork is damaged. If the air can't get to it it won't corrode. With Sikaflex the excess can be cleaned off straight away using turps substitute or white spirit. Thumbs Up Just a tip! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #110255 27th Dec 2011 7:17pm
ZeDefender
Cheers Thumbs Up
Think I'm all set Very Happy Tell someone you love them today because life is short.
Post #110292 27th Dec 2011 9:45pm
ickle
On the grandmother sucking eggs line, use masking tape to stop a drill wandering on a panel, if you centre pop a panel (as advised in LRO a while back) you will get ripples and circular dints in the panel - might get away with it around the window frame as the panel is narrow, but a sharp drill and tape is better....
Keith
Post #110300 27th Dec 2011 10:36pm
T1G UP
Keith
exactly.
Post #110308 27th Dec 2011 11:28pm
ZeDefender
Thumbs Up Tell someone you love them today because life is short.
Post #110310 27th Dec 2011 11:54pm
