Home > Puma (Tdci) > Low Ratio
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
Low Ratio
Hi
a quick quesetion, when yoiu select low ratio, do you get a light on the dash to let you know? not the diff lock warning Cheers
keith
puer claudius
Post #10949 16th May 2009 6:37pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
No. a quick answer to a quick question Wink Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #10950 16th May 2009 6:42pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
No light needed - you soon know about it Very Happy
Actually - how do you select low on yours? is it a lever or button? Does your auto sit in front of the transfer box - in which case, how does it handle the double d clutch required for the change? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #10954 16th May 2009 11:04pm
mse
No - but ive been doing some investigation into the light on the dash because it was supposed to work.
I know all the wiring and switch is there, in theory from reading the workshop manual and electrical manual it not only should light, was planned to light, but all the parts to make it light are there.
Im going to wait to see where the break in the chain is. Mike
Post #10960 17th May 2009 8:26am
kljw
Mike
keep us all aposted, would be good to find out if we can get it to work. Cheers
keith
puer claudius
Post #10980 17th May 2009 5:36pm
mse
kljw wrote:
Mike
I will, its one of those things that serves little need but would be nice to have. Mike
Post #10984 17th May 2009 5:43pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
If the wiring and switch are present surely it would only need the dealer to activate it through the ECU. It would be nice to know if that's possible. 130 crew cab
98 V8 Disco
Post #10988 17th May 2009 5:46pm
kljw
Mike
here's one for you. have posted in relation to this, but not worked out the answer yet. i am trying to bypass the signal that is sent to the ECU when you select low ration, reason being, is that i want shot of the idle jack. i have an auto box fitted, and the idle jack causes problems due to the ratios in my gearbox. i have thought about just pulling the plug off the sensor, but not sure what the effect may be. any thoiughts, let me know. Cheers
keith
puer claudius
Post #10989 17th May 2009 5:49pm
mse
I have access to this and im going to play with it hopefully next weekend if the kit is free...im sure i know where the option may live, i know the switch is there...i know the grey black wires are there, i also know the position in the dash is there (green light that doesnt turn on on self test) - the pre release mule had them.
So its either an option or not, it may also end up being more complicated! the feed does do some engine management tasks i understand.
Quote:
Mike
The low switch is the grey connector on the right rear of the trans. box - remove this to try its only a connector...you wont be able to have your light on the dash though if i work it out. Mike
Post #10991 17th May 2009 5:53pm
kljw
Mike
my thoughts are, that if i remove the connector, and this achieved what i wanted, then i could put a swhich in line, so that when desending, and need to loose the idle jack, i can flick the swhich, the low ratio light would go out, that way i would know idle jack has been by-passed.
let us know how you get on. Cheers
keith
puer claudius
Post #11027 18th May 2009 9:58am
