Home > Td5 > rear bulkhead cab 90
Monstertuning
any one have a photo of how a rear truck cab ie highcap rear bulkhead fits to a 90 inch www.monstertuning.co.uk
Post #108479 19th Dec 2011 5:42pm
T1G UP
same as a rear tub, on the out riggers
Post #108480 19th Dec 2011 5:55pm
Monstertuning
on a 110 there are 4 brackets on outrigger and 2 straps that sit back , on a 90 the two furthest brackets fit but the two inside brakets are not there , the cab is also up in the air as the bottom brackets have nothing to sit on , land rover did fit this to 90 inch but im having no luck with a picture of the brackets installed . www.monstertuning.co.uk
Post #108557 19th Dec 2011 9:36pm
Post #108603 20th Dec 2011 7:56am
Zagato
Not sure this will help but as so many things were carried over...a rear 88" bulkhead is different to a 109" bulkhead and I think it's sits in a slightly different position also, not sure if that helps, somebody with more knowledge should be along soon!
Post #108642 20th Dec 2011 10:20am
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
There are 2 uprights on the tubular outriggers(2 bolts in each),the only other mounts on a 90 are on top of the a-frame crossmember inside the chassis rails that link to the underside of the seatbelt mounts on the rear bulkhead/tub
Paul
Post #108864 20th Dec 2011 11:47pm
