Home > Maintenance & Modifications > Castrol_oil_update_SSM50837 |
FYI, from Topix:
WSS-M2C934-B specification engine oil used in DPF equipped vehicles 2.7 TDV6, 3.0 TDV6, 3.6 TDV8, 4.4 TDV8, Defender 2.2 Puma and Freelander 2.2 TD4: Castrol SLX Professional Powerflow C1 5W-30 is replaced by Castrol EDGE Professional C1 5W-30 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
20th Dec 2011 12:08am |
The complete bulletin
Reference SSM50837 Models Freelander 2 New Range Rover Defender Discovery 3 Discovery 4 Range Rover Sport Title Land Rover Engine Oil (Castrol) Branding Update Category Engine Last modified 28-Jul-2011 00:00:00 Symptom 401000 Oil System Concerns Content Issue: Castrol engine oil as used in Land Rover products update. Action: From the following dates Castrol SLX Professional Engine Oil is/will no longer be available to order from your Castrol representative: June 2011 – Europe & Africa September 2011 – Turkey, Asia and Pacific November 2011 – Brazil 2012 – North Americas and LACRO Details of the changes WSS-M2C925-A specification engine oil used in 5.0 V8 Gasoline Castrol SLX Professional Fuel Saver A1 5W-20 is replaced by Castrol EDGE Professional A1 5W-20 WSS-M2C934-B specification engine oil used in DPF equipped vehicles 2.7 TDV6, 3.0 TDV6, 3.6 TDV8, 4.4 TDV8, Defender 2.2 Puma and Freelander 2.2 TD4 Castrol SLX Professional Powerflow C1 5W-30 is replaced by Castrol EDGE Professional C1 5W-30 WSS-M2C913-B/C specification engine oil used in 4.2/4.4 AJV8 Gasoline and non DPF Diesel engines 2.7 TDV6, 3.0 TDV6, 3.6 TDV8, 4.4 TDV8, Defender 2.2 Puma and Freelander 2.2 TD4 Castrol SLX Professional Longtec A5 5W-30 is replaced by Castrol EDGE Professional A5 5W-30 ACEA A5/B5 specification oil used in Freelander 2 I6 3.2L Gasoline Castrol SLX Professional Longtec 0W-30 is replaced by Castrol EDGE professional A5 0W-30 The above stated lubricants are available in bulk, barrel or packs. For ordering these products, or if you have any questions regarding pricing, minimum order quantities, lead-time, please contact your local Castrol representative or your local distributor. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
20th Dec 2011 12:12am |
I might have missed it but there's no mention of PUMA 2.4 - so I guess it's not changed?
20th Dec 2011 7:28am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
No 2.4 ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
20th Dec 2011 9:15am |
It also suggests that there's a non-DPF version of the new 2.2. ROW spec perhaps? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
20th Dec 2011 9:32am |
so no change to the 2.4 oil spec
20th Dec 2011 6:34pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2632 |
Indeed, SA-spec 2.2 Pumas do not have a DPF due to poor diesel quality in Sub-Saharan Africa -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Jan 2012 6:56am |
