Home > Puma (Tdci) > Rear Passenger Door Seals
leeds
Anyone got good tips for keeping rear passenger door seals on 09 USW where they are supposed to be?
We don't use rear passenger doors very often but they were a right PITA yesterday when we had passengers. . Got chewed up by the door closing as well.
Can see a visit coming onto main dealers saying fit new door seals which actually stay put.
Brendan
Post #108093 17th Dec 2011 6:32pm
K9F
Had a similar issue with the rear door seal on my 90, bottom left hand side! Removed the seal cleaned off the area, small bead of Sikaflex adhered the seal to the frame and liberally coated the door with silicon based grease to prevent the door from snagging it and pulling it off when closing. No issues since as the seal forms to the correct profile eventually. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #108098 17th Dec 2011 6:49pm
bob neville
Hi Brendan
I don't have a problem with them staying put, front and rear leak like sieves though Laughing
Try taking the seal off and gently closing the inner edge with a pair of pliers or grips. This should close the u shaped inner metal lip and keep it in place.
Good luck Thumbs Up
Bob
Post #108099 17th Dec 2011 6:52pm
Grockle
Brendan, all you need is some dum dum (bodycorking) Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #108110 17th Dec 2011 7:35pm
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Shocked
I have the same issue on the left hand rear passenger door of our 07 USW! although can't imagine it's only these models which suffer this problem!!! we use our rear doors all the time for our nippers and is now becoming a royal PITA! Will give the gum gum a shot or failing that the silkaflex and if they fail some new seals.
Cheers for crimbo card too Brendan and Barbara Thumbs Up Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #108120 17th Dec 2011 8:55pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Just had all mine (all 4 doors) replaced by dealer under warranty, let's see how well these last. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #108314 18th Dec 2011 11:17pm
