Home > Puma (Tdci) > Puma engine light
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Puma engine light
Hey guys. Just popping out and suddenly the Landy went into limp mode. I have the engine management light and the ESC light lit up. Any ideas?
2015 2.2 110 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1066285 25th Apr 2025 3:49pm
Ianh
Best use a code reader to get diagnostic trouble codes.that will help diagnose and locate issue. However looks like it’s an abs sensor / abs issue.
You can get a vLinker MC+ For about £53 and use the torque app (free) or torque pro app (circa£5) to read and clear codes from your phone.
Post #1066286 25th Apr 2025 4:04pm
Andyslandytd5
Cheers Ian. Will order one up and give it a go 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1066287 25th Apr 2025 4:12pm
Ianh
There are other elm327 readers that are a lot cheaper, but I don’t advocate connecting cheap Chinese electronics to expensive ECU’s.
VLinker are Chinese but of good quality from vgate , just make sure you get from vGate themselves, else you may get a fake copy !
I think they have a shop on amazon so if you have prime you can get it quick.
As a generic reader you can use on any vehicle with an OBD2 port, plus it can run more detailed vehicle diagnostics for GM and ford vehicles when using vehicle specific apps.
Once you have the DTC’s record them , then delete them. This should take your vehicle out of limp mode. You can then do a search on the net of the DTC’s and their possible cause, and post on this topic so the forum members can help.
Also once DTC’s cleared drive the vehicle a short distance to see if the DTC’s are triggered again.
Ps. While awaiting your reader have a look under the vehicle at the ABS sensors at each wheel to see if the wiring and connectors are ok. In addition it could be one of the ABS sensors not seating correctly. The DTCs will point to which one if that’s the case.
Post #1066288 25th Apr 2025 4:36pm
Andyslandytd5
Cheers for the guidance again Ian.
So I borrowed an ODB reader from my brother and it gave me the code P2127 (Throttle/Pedal Position Sensor/Switch 'E' Circuit Low has been detected). I cleared the code and tried it again and still had the lights and error.
I think checked the wires by the pedal and pushed the connectors together, cleared the codes and tried again and the lights were gone and it was out of limp mode. Took it for a spin up the road for abit and so far so good.
I only have a few short trips tomorrow so will see how it goes. Fingers crossed it was a loose conncection or something.
Its odd I have the DSC light on too but the error was the pedal. 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1066307 25th Apr 2025 8:41pm
lightning
Take the connections apart and spray some electrical contact cleaner on them, then put them
back, and the fault is less likely to return in the future.
Post #1066308 25th Apr 2025 8:56pm
andy63
I'm not saying this was the case as I don't know what tool you used, but a generic obd reader wouldn't be capable of reading abs /dsc fault codes unless it had the the necessary software installed..
If its just obd then it wouldn't, I don't think..
Post #1066311 25th Apr 2025 9:13pm
LET'S OFF-ROAD
I've been wanting to get a code reader for a while as I also have an intermittent limp mode problem so thanks for the info!
I just ordered this as you suggested, direct from vgate on Amazon:
https://www.amazon.co.uk/vLinker-Bluetooth...B088LW211V
Post #1066313 25th Apr 2025 9:18pm
Ianh
Please see the list of valid OBD2 codes that a good generic obd2 app, coupled to a good bluetooth reader should read. The ones beginning with C are relivent to the ABS and it’s sensors . https://www.autoequipment.com.au/image/dat...0CODES.pdf
Post #1066327 25th Apr 2025 10:41pm
Ianh
It’s basically a copy of the OBD2Link MX+ device, but at half the price. The only difference is the OBD2Link device has a communication chip that can run twice as fast as the vGate one. However the current OBD2 specs can’t make use of the extra speed. So the gen vGate MC+ is a good buy.
Note. If you have a 2.4 you can run the forscan app to give you more specific TDCI diagnostics. This is not the case for the 2.2
Post #1066332 25th Apr 2025 10:57pm
andy63
Yes i know what you mean, my wording should probably have indicated that generic obd only has access to the powertrain module and the codes that are relevant to it..
It doesn't include abs, instrument cluster and the manufacturer specific codes that can be generated..
That's what I have found with the couple tools I've used..
Obd is a separate section in the menu and can not look at all the installed ecus on the car....on my defender the only modules installed are instrument cluster, abs and pcm..that is the network and an obd reader can't access the instrument cluster or abs on the network without the necessary software.. that's the way I've found it to be anyway..
Post #1066342 26th Apr 2025 7:21am
